i just want to ask how to turn off the vibration when pressing. thanks
@Rhoderick
Hi Rhoderick😊
Thank you for reaching out! To turn off the vibration when pressing, you can easily do this by accessing your quick settings.
Open the quick settings and scroll down to find a moon icon which represents "Do Not Disturb" mode, and toggle it on. This should stop the vibration when pressing.
If you have any more questions or need further assistance, feel free to contact us!
@iKKO thanks for the help but when i put in do not disturb the sound is also turn off, i just want to turn off the vibration only when pressing.
@Rhoderick
Hi Rhoderick,
Sorry for the wait! Currently, we're unable to disable the vibration as it's intended to provide haptic feedback and enhance user interaction with the screen. However, rest assured that your feedback has been noted on our developer's Checklist.
Stay tuned to our community forum for any future updates!😀
