Battery
  • The battery seems to be inconsistent on both sides and after not using the earbuds for a day or two the battery seems to have leaked and is completely empty and in need of charging. I have owned the air buds for 2 weeks with minimal use
  • Dear Vivian,
    Thank you for reaching out!
    We're sorry to hear about the battery issue you're experiencing. To ensure you receive the best assistance, please contact our official after-sales support team at support@ikkoaudio.com. They’ll be happy to help you troubleshoot the issue and provide a solution.
    Thanks again for your support—we’re here to help!
    Best Regards,
    The iKKO Team
  • It’s likely a battery Stickman Hook Game or charging case issue—sometimes one side doesn’t seat properly in the case or there’s a defect causing drain when idle.
Please login to reply this topic!
