Option to delete ChatGPT chats from earbuds case nor voice prompt
  • I noticed the ChatGPT chat history doesn't have any option to be erased, it would be more
    personal if we have this option to erase history of question both via earbuds case and via voice prompt. There are time we have some embarrasing or very dumb question to  ChatGPT, so a little bit of privacy to the sent messages to ChatGPT would go a long way.
  • @She
    Thank you for your valuable feedback.
    We understand your concern regarding the privacy of your chat history with ChatGPT. Currently, the device only stores the last 15 conversations locally. For erasing all local prompts, you can clear the launcher data to delete the stored messages.
    We will also forward your suggestion to our technical team to explore the possibility of erasing prompts more conveniently.😁
  • The steps to erase local prompt:
    1. Go to settings --> Apps & notifications;
    2. Tap "Launcher" , then "Storage";
    3. Tap Clear Data.
    Then the conversation with GPT will be deleted!
Please login to reply to this topic!
