Stand alone device questions
  • I am in the process of cutting down the amount of time I use my smartphone and think this would be a great way to do it.  I want to use these headphones as a stand alone device. I have one in my cart, but thought I'd ask some questions first.
    1. Can you send text messages?  Voice or keyboard?
    2. Maps and directions?
    3. Does it have a hotspot option?
    4. Can it be used without a phone?  I'm okay with using a phone for setting it up, but I just want to take the SIM card from my phone and install it in the case.
    5. Can it keep contacts organized and have new ones added?
    6. Can the ChatPAL system be used for messaging, or option changes like the dumb phone assistants can?
    Thank you for any answers
  • @Tyler
    Hi, Tyler!☺️
    1. Yes, you can send text messages with ActiveBuds. We have introduced voice-to-text functionality, and you can also type your messages.
    2. ActiveBuds come equipped with a GPS app.
    3. Yes, once a SIM card is inserted, you can enjoy 4G connectivity and also use the hotspot feature.
    4. The ActiveBuds can be used independently. By inserting your SIM card into the ActiveBuds, they can operate standalone without the need for a smartphone.
    5. That's a great suggestion. We will forward it to our technical department. After an upgrade, we plan to introduce this feature.
    6. ChatPal can assist with your daily or academic questions and can save its answers to be sent to your other devices. As for other functionalities of ChatPal, we can look forward to them together. Our ChatPal is constantly evolving, and you can enjoy the surprises it brings with continuous upgrades.
    Should you have any questions or need further assistance, please don't hesitate to reach out to us at any time. ❤️
  • 請問有IOS版的嗎
Please login to reply to this topic!
